Thanks,
nixter wrote:How then do I lower my brew pressure?
nixter wrote: I don't want to adjust the pstat do I? I did a basic thermometer test of the brew temp and it's only just above 140f. (60c) Mind you I was just holding my small frothing pitcher under the brew head and measuring the water temp in the pitcher, not ideal I know but it still seems low.
barry wrote:foam cup method:
take a small foam cup which will fit up against the group gasket (6oz is about the right size), and push a dial stem thermometer through the side about an inch up from the bottom. angle the thermometer stem downwards across the cup and wedge it into the opposite bottom corner. to measure brew water temp, remove the portafilter from the machine and hold the cup firmly against the group gasket on the underside of the brewhead in such a way that you can see the thermometer dial. run about 2oz of water into the cup and watch the thermometer dial for the maximum temperature reached. it's easy to get burned doing this, so be careful not to let hot water run onto your hand.
nixter wrote:If I adjust for a max blind pressure of 10 bar then won't that eliminate the possibility of brewing under too much pressure?
