by shadowfax on Fri May 01, 2009 11:15 am
Dang, that beast is in great condition on the inside. I bet you got a steal!
Do you happen to know how long the machine sat unused? Rotary pumps can easily lock up if they are unused for long periods of time and not totally cleaned out. Not sure why, but it's a pretty minor thing I think. You may need to pull the pump off the motor and turn the shaft with a wrench to get it going again--at least, that's what I had to do with my pump. You may want to also do a simple descale by mixing 1 tbsp/L of citric acid in a bucket and brewing it through the machine. This may help clear any minimal scale in the pump that may give you trouble; also, the grouphead on any old machine is almost always scaled. they have such constant temperature changes due to the nature of heat exchange that they usually scale worse than anywhere else on the machine.
Anyway, my point about the seized pump--that's just a guess, the motor will make a funny noise that doesn't sound good, but doesn't sound distinctly horrible when it's seized. That's why I suspect pump seizure on your machine, based on your description of the noise. You can also get a bad noise like that from a sticky solenoid valve, but you should be getting pressure on the brew pressure gauge if your pump isn't failing. Anyway, to check if your pump is seized, you just need to unscrew the clip that hooks the head to the motor, and pull it away. You should be able to turn the shaft that you expose pretty easily. If it's stuck, that's your problem. It should also have a smooth action as you turn it. You should be able to check without unhooking the water supply, since the hoses are both flexible.
Good luck; let me know if that works. By the way, try using the machine with the case off and take a listen where the noises are coming from, that can aid diagnosis a lot.
Nicholas Lundgaard
