Rob, I went through the same process/rationale you did with my G. Evol. After an initial 'getting to know you' period, I started cranking the Sirai PStat up by 360° rotations. (My initial pressure settings were Pmax= 1.07, Pmin= 0.83). Made coffee at each. Kept track of the min-max pressures according to the gauge. Went all the way to plus-four revolutions, which was Pmax= 1.2, Pmin= 0.96 bar as measured on my machine.
I did tended not like the way the machine behaved at the higher settings, or the espresso it made (though I figured out how to best use it after some experimenting). It took more flushing to get to a good brew temp the higher the Pstat setting. So I started turning the Pstat down, again by 1 screw revolution at a time. It was surprising to me how well the pressures going down matched those I measured going up.
On reaching the initial start setting, I continued on down to minus two revolutions of the Pstat screw. This got my machine to Pmax= 1.01 and Pmin= 0.80. This is lower than the factory setting, and I like it the way it is. The flushes are MORE than eric's "2 ounces", but noticeably less than they were at the Pmax setting of 1.2.
Moreover, I find pressure is STILL way above adequate for steaming milk - I can make nice microfoam in a short period of time - not timed, but I'd guess about 30s.
So I'm happy at -2 revolutions of the Pstat screw for right now.
FYI, I find Eric's Thermometer an invaluable aid in flushing my G.Evol. Only thing to keep in mind is there is a small but significant time lag in temp readout, and once you have that down, it's duck soup. Not trying to shill here, but I couldn't manage too well without it. I also used a Scace device which provided faster readings at the group exit point, as well as the actual temp delivered to the puck. Great for correlating the E61 thermometer readings and actual 'water on the puck' temps - but the general correlation of the E61 temps (in the brewhead) being about +3°F higher than that delivered to the puck are reasonably accurate.
To sum,
1) the Rocket factory setting may be set where it is (low) for a reason.
2) the lower pressure range settings seem to work better for whatever reason, and steam pressure is still way more than adequate.
3) being able to measure the temp above the brewhead during flush is very helpful for developing an effective flushing technique.
Finally, I suspect the pressure readings from any of these machines are not terribly accurate and have a pretty good ± between individual machines. However, for an individual machine, the pressure settings seem pretty repeatable.
If anyone would like a relative graph of Sirai Pstat pressures vs "± cranks of the screw" on a G.Evol. I could probably figure out how to post a jpg of my graph as an example.
It's a nice machine and can make really nice, and very consistent espresso.
Regards,
Al
