New noisy rotary pump
Postby mitch236 on Fri Oct 28, 2011 10:29 am
Last week my OEM water pump seized up so I ordered a new pump. Since the OEM replacement was on backorder (Procon) I ordered a similar pump (Hydropure Rotary Vane Pump). The Hydropure is very noisy. The Procon when it worked was very quiet. Should I worry about this or is a noisy pump normal? Maybe the quality of the Hydropure isn't up to the level of the Procon?
mitch236
Postby Randy G. on Fri Oct 28, 2011 10:59 am
I will ask, just in case, is it pumping water? I know my Fluid-O-Tech gets real noisy when the supply line is turned off (as in forgetting to turn the valve back on after doing some sort of maintenance which requires closing the supply valve).
Espresso! My Espresso!
Randy G.
Postby erics on Fri Oct 28, 2011 11:28 am
Mitch -
Exactly what pump did you order/install? The EP website - http://www.espressoparts.com/cgi-bin/ep.pl shows a Hydropure pump rated at 140 gallons/hour (gph) and the Hydropure website shows pumps going down to 16 gph.
140 gph = ~147.2 milliliters/sec ; 16 gph = ~ 16.8 milliliters/sec. The AVERAGE flowrate during espresso production is ~ 3.0 milliliters/second. Yes, sometimes you need to fill the steam boiler :) - hopefully not during the event. Lots of water is being bypassed during normal operation = a good source of noise. I do believe you would have been better off with the "baby" pump.
edit - this is the pump manufacturer that Hydropure uses - http://www.nuert.com/espresso-machine-pumps.php
Skål,
Eric S.
http://users.rcn.com/erics/
erics
Postby mitch236 on Fri Oct 28, 2011 12:29 pm
Eric, I think you're right. I will call EPNW today, thanks!
mitch236
Postby erics on Fri Oct 28, 2011 12:34 pm
In the event you do not know this, Hydropure is your next door neighbor - http://www.adernet.com/hydropure/index.html - well, maybe :) . He SEEMS like a real nice gentleman of Italian descent and may very well be a faster route than going back to EPNW. Maybe refer him to this thread and mention that you "talked" to me.
Skål,
Eric S.
erics
Postby mitch236 on Fri Oct 28, 2011 1:55 pm
Thanks Eric!!! He was great and he is sending me a 35 GPH pump.
I tried to explain the gear driven pump idea you have been working on but he didn't understand what I was talking about. It would have been great to have him help me with my system since he's so close!
mitch236
www.baratza.com: skilled in the art of grinding
Return to Espresso Machines
