So, the Astra, totally different beast (and she IS a beast). Second day I had it, I was pulling shots, same coffee, same grind. I pulled 2 awesome shots, then the third, it was as if the pump lost pressure. Water barely came through. I went coarser and coarser on the grind, it didn't matter. I tried the Expobar, had it dialed in in two shots.
I took it to Astra, they checked it out, and said it was vapor lock. They checked brew pressure, and said I was good to go.
So I've been playing around with the grind, tamp, etc, and it really seems like brew pressure is low. I am using a naked PF with double basket, grounds are not contacting the grouphead, but it's extracting...oddly. It's extracting slowly, but the end result is a bit watery, not syrupy or over-extracted. It actually tastes really good, but the consistency is almost like from a moka pot, if that makes sense, it lacks viscosity. Crema is also thin; crema was never an issue on the Pulser, and it would last long, but this is on the thin side, and dissipates rather quickly. Oddly, coffee that extracted this way on the expobar would've tasted like ass, but again, this tastes good, just not quite 'espresso'. Normally I'd tighten up the grind, based on the wateriness, but that just chokes her.
The puck is soft, btw. When I knock it out on the counter, there are more grounds adhering to the sides of the basket than I'm used to, I'm used to knocking the puck out, and a pretty clean basket. The puck it dry, but soft-ish. It comes out in one piece, and stays together, though.
Otherwise, she's beautiful, steam is ridiculous, and overall build quality seems insanely good. So what's the problem?
