Randy G. wrote:iirc, you should NOT use the citric acid solution on a machine with an aluminum boiler. Verify the material that the boiler is made of before proceeding and do some research as to the correct chemical to use for that machine. Citric Acid and related commercial products such as that are fine on stainless and brass (and copper?) but not for aluminum iirc.
But the people who run the Gaggia group on Yahoo insist that citric acid IS fine to use and that it will not harm the aluminum boiler. They claim to be very tight with the US distributor as well and apparently base their statements on convos with the distributor / tech dept.
They state that the 2 Tbsp citric acid per liter H2O is correct amount for these aluminum boilers.
What makes you say it shouldn't be used on those boilers? What would happen, and do you have some idea why my water keeps having white residue now? I would definitely like to know and I like to hear all sides on these things--you see how confusing this all is for the consumer...
What chemical do you suggest for aluminum if citric acid is not right?
Thanks.
