EspressoGirl wrote:You mentioned the gas--that is what I was wondering about--what could that be?
I clean the shower screen in Joe Glo and did that last weekend. It was descaled too. I clean the dispersion block regularly too. It doesn't look like coffee -- just this filmy bubbly stuff. But there is really a lot from the grouphead. And sometimes some from the steam wand.
How much detergent do you use for your backflush? I'm wondering if the filmy bubbly stuff might be soap residue in the group and water path from using too much detergent. If that's a possibility, backflush with plain water until it goes away (2-3 seconds max per backflush.) You might want to drain and flush the boilers with bottled spring water, too. Crystal Geyser or Poland Springs should be safe scale-wise but will have some mineral content as well.
I'm not a water or minerals expert, but perhaps aluminum oxide debris swirling around in the boilers is somehow causing small air bubbles to get trapped in the water. Then it comes out of solution when it exits the group. The bubbles could be filmy because they're picking up a small amount of normal residual coffee oils.
