by another_jim on Tue Sep 01, 2009 7:23 pm
If the white residue tastes of lemon, you may have gotten something weird, like citric acid plus xanthan gum. But I doubt it. If you live in NYC, there's a good change you have soft water. This means descaling anything is a waste of time, and the white stuff is anodic corrosion* from the infamous Gaggia brass/aluminum sandwich boiler. (*In the presence of soft water, which is slightly acidic, a join between two metals acts like a battery, with the anode, in this case the aluminum, supplying the metal ions. This means the aluminum gets eaten away. This is called anodic corrosion)
These boilers work and descale great in the hard water common in Italy, but they can fall apart in 6 months in very soft water. If you live in the part of Manhattan or Brooklyn that gets the Finger Lakes water, your machine is probably close to toast already. Alan Frew from Oz, where the water is similarly soft, once had lots of pictures up of corroded Gaggias. I'm not sure if they are still around.
