I've just had a similar issue with a VBM Domobar.
The thread that Tom is referring to is here:
Vibiemme Domobar Super - boiler not filling! .
I agree that this can (obviously) also be the cause of a boiler not filling but the big difference between the two causes is that one is typically more gradual (scale) while the other is typically instantaneous (boiler fill valve malfunction). Pump pressure on Anita is ~ 3.0 bar when operating in boiler fill mode alone. I'm not sure what it is on the Vibiemme but it must be SIMILAR. The buildup of scale in the boiler fill line would cause a gradual increase in this pressure and a corresponding increase in fill time.
In the case of this particular machine (Dave's Anita), the problem was solved by descaling the disassembled boiler fill valve in white vinegar for about an hour.
This was done after syphoning the majority of water out of the boiler via the hot water tap connection and checking for proper voltage applied to the solenoid.
