Need some La Marzocco Linea PID mod help - Page 2
Postby mkraft59 on Sun Dec 26, 2010 12:17 pm
Hello mitch,
if possible, please send the pics to mkraft59@web.de
thank you for help
Michael
mkraft59
Postby mitch236 on Sun Dec 26, 2010 2:10 pm
Here's the SSR wiring. The Red, Blue and Green wire are my supply. It is part of a low voltage 6 wire cable. The White and Orange wires are from the Linea. The White is the heater element and the Orange is the front panel light (lower right screw). The White on upper right screw is also from Linea and I think it came from the old thermocoupler. (all this is from distant memory). The remainder of the wiring will become clearer in the following pics.
The back of the PID controller. You can see the Blue sheathed cable with two wires. The is from the new thermocoupler. The bottom white sheathed cable is my wiring. You can match up all the wiring with the SSR except the white wire which is line feed (220v) for the controller.
mitch236
Previous
Return to Espresso Machines
