Mojoman wrote:First, should I also add a line regulator and pressure gauge between the filters and my machine?
I recently answered this same question in
Pressure regulator on La Spaziale Vivaldi 2:
"The recommendations depend on the manufacturer. According to the repair technicians at Chris' Coffee Service, if the pressure is too high, the grouphead solenoid may fail to close (drip, drip, drip). They recommend a point-of-service pressure regulator to reduce pressure to ~2 bar. I agree with their recommendation, if only to assure a stable input pressure and to act as a backflow preventor (i.e., if mains pressure fails, water isn't sucked out of the espresso machine).
In our area, the main line pressure is around 110 PSI and the house pressure regulator reduces it to 55 PSI. Unless you plan to use lines pressure for preinfusion as described in
How to Preinfuse; Extraction Pressure Redux, I would go with their recommendation of 2 bar. They've sold hundreds of Vivaldis and are certainly qualified to speak with authority on the recommended install. More generally, there's lots of threads discussing this question; below is a sample:
You could ignore these recommendations and hook it up directly. I have a dishwasher, ice maker, clothes washing machine etc. and none have a point-of-service water pressure regulator. Then again, none of them are fussy about the water pressure stability while in use; rotary pump espresso pumps are for the reasons provided in the last thread above, so I would follow the manufacturer's/vendor's recommendation."
Mojoman wrote:Also, someone on this site recommended adding a T adaptor between the filters and machine to be able to flush the water when a filter change is needed. Are these good things to do? Any other recommendations?
That sounds like a smart idea. You could also use the same setup for drawing descale solution from a jug (i.e., close the post-filter system stopcock; instead of purging the filter carbon particles into a bucket, the espresso machine pump draws descale solution from a jug).
