chamlight wrote:Hi Jim
Thanks for your super prompt reply.
Can i bypass the thermal switch temporarily to see if this is the problem?
Rob
While you likely can, this may be pointing to a problem with a pressure-stat failing to open with age/scale/etc. Relatively inexpensive to fix. Do you see the power to the boiler cycling on/off? I don't know if this machine has a indicator of the boiler being turned on, but you can likely hear it cycle on/off. Failure of this part would allow a machine to heat up and then to keep going until either the p-stat worked or an emergency over heat circuit kicks in.
Be really sure there is enough water in the boiler, or you could also risk burning out the heating element.
Mark
