when I have the machine on or off the water pressure is basically kinda going through looks like a overflow hose down into the drain line ?
hope that makes sense to those that have the A3 or T1
where you hook up your drain line just before on the brass lines is a clear hose that is coming down to that and that is where the water is dripping in from
the hose comes from the back of where the group head sits
I replaced that wired coil once that is inside that chrome housing just below the group head the one you take off with the small 6mm or so size nuts ? but that is where the hose goes into that area and then goes down to the drain ?
looks like from the schematic the Solenoid valve pilot - 3 ways ? anyone have one of these fail ?
I am not so good at mechanics of espresso machines but good at mechanics
thanks so much
