Need help to adjust boiler pressure on ECM Giotto Classic
Hi all,
I want to reduce boiler pressure on my ECM Giotto Classic but I don't know where I make this adjustment. It's a plumbed version from the year 2000 and it doesn't quite look like other Giottos I've seen when I searched the forum.
Except for the vacuum breaker valve, boiler safety valve, water level probe and OPV I really don't know what all parts are called, or what they do...
Any help would be much appreciated.
- HB
- Admin
I don't recognize that pressurestat (?), but How to adjust an espresso machine pressurestat has general advice that should help.
- cuppajoe
The black and white box with the wires and attached to the copper tube is the pressurestat. Do you see any means of adjusting it? Look for a knob or slotted shaft, and possibly +/- indicators. Perhaps that red thing.
Is there manufacturer or model number on it?
David - LMWDP 448
Some Pstats that haven't been messed with have a protective plug- that covers the adjustment screw. Make sure you are turning the adjustment screw and not just the plug covering it. .
Pressure increased with around 0.1 Bar after adjusting so I guess clockwise is the way to go instead.
The thin layer of red plastic covering the screw came off when I started adjusting so obviously this part has never been touched.
Thank you for your replies.
