I was lucky enough to come across a beautiful older (1996) Bezzera BZ40 on Craigs List for $225! (Had a bad heating element)
For anyone interested, you can see pictures here:
http://beefstorm.com/pics/Coffee/Bezzera/I am dieing to hook it up and start using, but am a bit intimidated about plumbing it in, and am very limited by space. I am hopeing you all could give me some help/advice!
Issues:
1. Physical Connection To water supply.-It came with a braided SS hose with a female BSPP connection.
BSPP - (Parallel) Seals on 30° chamfered seat
BSPT - (Tapered) Seals on Thread
I want to hook up a John Guest connection to the female BSPP connection on the SS Hose. The only problem is I can only find Male BSPT to John Guest connections online (Stefano's espresso Care & Chris's Coffee). I don't know if they are mis labled, or if they just dont make that connection. This doesn't make any since to me because from my understanding Euro espresso machines all use BSPP connections, but maybe I am mistaken.
2. Water Filtration/Softener
-The only water source I can tap in my kitchen is the one behind my refrigerator. I only have about 1-2in clearance max between the refer and the wall, which really limits my options for filters/softeners. Above the fridge is a short cabinet I could house filters in, but it is only about 10" high, so I wouldn't be able to mount most filter units in there.
I used a hard water test strip and my hardness is about 50ppm, which I believe is pretty good. At this level, is it possible to get away with not having an inline softener, as long as I keep up on my descaling?
If I am unable to fine an inline particle filter that will fit my limited space, how bad is it to run the setup without one?
My rough plan is the following:
Use a Max Adapter (Chris's coffee) off of my refer's water line and use John Guest tubing. In that line I want to have JG shutoff valve, JG Check Valve, and a pressure regulator. If I have room, and they are deemed necessary, a particle filter and softener. What do you all think?
