Need help -leaking steam wand -old anita
Postby shuki on Sun Feb 15, 2009 5:03 pm
i have the old quickmill anita with the steam wand that rotate on one axis only, it start to leak
how can i fix it? what do i need to replace?
thank u
shuki
Postby HB on Sun Feb 15, 2009 5:10 pm
Where is it leaking from? If it's dripping out the end of the wand because it isn't sealing, see Where can I find a replacement stem for compression steam valve?
Postby shuki on Mon Feb 16, 2009 3:42 pm
thank u
its leaking from the end of wand -ill try sealing it
do you know where can i find a diagram of the steam wand?
shuki
Postby HB on Mon Feb 16, 2009 9:47 pm
shuki wrote:do you know where can i find a diagram of the steam wand?
Chris' Coffee FAQ #18 Andreja Premium: What makes their valves superior most? has good photos of the valves disassembled.
Postby quar on Tue Feb 17, 2009 2:03 pm
When ordering this replacement stem make sure to add in a blister of Dow 111 lube as well. You'll need them both to make this repair. Note, this is not a Chris Coffee or Quickmill sourced part. Stefano carries these for repair of Isomac machines. That being said, I repaired my original style Anita steam valve with this parts with no problem at all. AFAIK, this is a fairly standard part uses in many compression-style valves. However, there was one poster who reported that their valve was harder to turn after using this part for a repair. Never heard if that resolved itself or not. The safest bet is to buy a full replacement valve assembly from Chris Coffee, but I wasn't willing to spend the 40 bucks when a $15 part could fix my problem.
Mike
quar
Postby n00b on Sat Apr 18, 2009 10:24 am
I was replacing the stock wand on my Anita today with a no-burn wand when the spring sprung out of the assembly together with the metal washer. I had no clue on how to assemble them back until I found this extremely helpful page with diagrams:
http://coffeetime.wikidot.com/no-burn-wands-and-steam-tips
Hope this helps.
My personal espresso blog: http://espresso.colinloh.com
n00b
Return to Espresso Machines
