by normriff on Thu Feb 16, 2012 10:33 pm
I dont believe limescale results from a reaction to the brass or copper of the boiler or it's fittings. It is a result of moisture evaporating and leaving what doesn't evaporate. Calcium or other mineral "lime scale".
With regard to the boiler, I'd leave it until it becomes a problem. (noticeable steam leak, water on the counter) and take it to a professional then. And not just any professional, a guy who works with copper and brass and food manufacturing products. I hope you "know somebody" local. I do. Not something I would do myself. I fix espresso machines, I'm not a welder.
The fitting to the pump is easy, I'm sure you've already taken care of that. I've found that vinegar is less than ideal for removing these limescale deposits. I prefer something more aggressive and not to have to soak for so long. I've been using powdered ascorbic acid although I do prefer something yet stronger than that.
The ball component of the mating pieces can wear a groove at the sealing surface and need to be replaced. The boiler fitting mates with this ball fitting and can sometimes be "redressed" ie with a flat file and or a 45 deg countersink. However, this can also be overtightened and when that happens, this fitting splits and actually leaks more, the greater you tighten it.
Probably, this didn't get tightened and it is now.
Norm Riffle
The Original "It's A Grind", Portland Oregon - Espresso and Coffee Equipment Specialist since 1992
