I believe I have a unique viewpoint on the Mypressi as I believe I probably use it more than anyone in the entire world
I have had the unit fully replaced 1 time. Then the sides broke and fell off the handle, and they sent me the "handle repair kit" which was actually just some 5 minute epoxy 2 new handle sides to glue on. The construction of the handle sides and how they fasten is pretty poor. More than half of the pins that hold it in place were broken through the mail. I have also had issues with the gas cap not sealing all the way (I believe it has to do with the handle sides not being in the right place). I have also experienced the trigger getting stuck down many times (when this happens, the only way to fix it is to force open the head to relieve the pressure, or else it will sit there for nearly a half hour slowly leaking out gas (even if cartridge and gas handle are removed).
Yesterday the sides fell off for the 2nd time, I re-glued them on again using the same 5 minute epoxy that they sent me, but that doesnt stop the other problems.
I am also experiencing sealing issues. The problem is how the lid and head seal together. The black rubbery plastic coating that goes on the outside rim of the head and on the underside rim of the lid is very thin on the edges, and this is where the seal is made. After repeat use, it starts to wear away (on both of them) and the tolerance is very close, so once that wears it wont seal without you holding it very tight. It doesnt matter if you get more O-rings from Espressi or not, it will still happen (I have went through 3 sets of O rings also).
So currently, to pull a shot, I have to turn the lid clockwise as hard as I can and hold it while I pull the trigger until the head builds up enough pressure to get the shot started. It is a pain in the but, it also means I cant get an accurate timing on my extraction because my hand is occupied.
Maybe if I got an o-ring of a larger diameter this would solve the sealing problems, I will have to check that out. At the bottom of this post I have some pictures showing what I am talking about. I also have a video showing what happens when the handle gets stuck down, as well as pics and video of what happens when it goes right.
I have contacted Mypressi several times over the past week to no avail. They are not answering their business phones or email. They were initially very good with helping me, but after the unit broke several times, they seemed less receptive towards helping me, which is sad because the product produces some primo espresso (comparable to the LM G/S 3 even when done right). I fear they may be going out of business in the near future if they dont straighten things out.
Any help would be appreciated, I mostly wanted to share my problems with everyone
I would also like to add that my unit has never damaged or mis-used in any way. It has never been dropped and has never even left my kitchen counter top .
Heres the link to the video that I mentioned showing the stuck trigger with the slow gas release:
http://imageshack.us/clip/my-videos/10/b7v.mp4/#
Heres a video of a good shot:
http://imageshack.us/clip/my-videos/703/jek.mp4/
