My poor Silvia has a hole in her head. - Page 2
- HB
- Admin
As shown in the diagram above, the hole is drilled at a sharp angle into solid brass, so it can't be perfectly round.vitomatt wrote:Seems very odd to me that the hole is... irregularly shaped
- Stuggi
Yeah, and there's no way that any corrosion from normal tap water could eat through inch thick brass, not without killing something else in the machine before it ever got that serious. But, if you were running Hydrofluoric acid...
Sebastian "Stuggi" Storholm
LMWDP #136
LMWDP #136
seeing is believing!
H-B strikes again with an answer!
Jon, thanks for posting the other pics.
Now get that gasket shim and let's party on!
Oh - anyone know if other machines also have a similarly type drilled hole for water dispersion?
- Randy G.
My $.02 ... It looks pretty filthy in there. There is sufficient evidence that a wire brush was used, but there is a lot of coffee debris. I wonder if it looked like that in the gasket's recess? You can see a good amount of coffee between the gasket and the group. That could cause problems. Remove the gasket and water reservoir, and turn the machine upside down. Use a solution of backflush detergent and soak and clean the brewgroup. You might put a small cloth in there and saturate it with the solution. Get all that coffee and of gasket out of there before installing the new one.
- shadowfax
E61 also has a pair of (~45°) tubes from the gicleur chamber to the grouphead, as shown in the classic diagram developed by Lino Verna:vitomatt wrote:Oh - anyone know if other machines also have a similarly type drilled hole for water dispersion?
From E61 Group Espresso Machine: Detailed Interior Schematics.
Nicholas Lundgaard
- Tag Team Jesus (original poster)
Good call, Randy. Like I said, it wasn't in my cleaning practice to remove the shower screen. Guess I should get into that.Randy G. wrote:My $.02 ... It looks pretty filthy in there. There is sufficient evidence that a wire brush was used, but there is a lot of coffee debris. I wonder if it looked like that in the gasket's recess? You can see a good amount of coffee between the gasket and the group. That could cause problems. Remove the gasket and water reservoir, and turn the machine upside down. Use a solution of backflush detergent and soak and clean the brewgroup. You might put a small cloth in there and saturate it with the solution. Get all that coffee and of gasket out of there before installing the new one.
Before I install the new gasket, I'll do what you said above.
cheers!
Excuse the crappy pic, but my grouphead looks a little bit different than yours.
The showerhead has a metal piece before it which goes into an indent. The "hole" you speak of is in that indent, and shoots into the metal piece (metal piece is a diffuser)
Also my "hole" is not as rough as the one in your picture. Is your silvia an older model? I didn't know they changed the grouphead?
godlyone wrote:Excuse the crappy pic, but my grouphead looks a little bit different than yours.
<img>
My Silvia is only 2 years old. It's not the latest model with the new spiffy portafilter handle and steam valve, but the model before that. I purchased my machine new in the fall of 2007.
Interesting that your Silvia has a hole in a different place. When was yours produced?
I don't have my (old) Silvia any more, but I'm pretty sure I remember it looking like godlyone's (i.e. the older version); it only has the jet breaker + shower screen that attach to that central screw. I assume that Tag Team Jesus's is the newer (pod capable) model with a big hunk of brass that directs water flow + can be swapped for the pod adapter.
yeah, that must be it. Mine is a V2 i believe (the model with a real rancilio label and the non-splined PF) but I have the older style drip tray (which i like better )
I think LordFoo is right - it is probably so you can easily use pods, but it's strange how on my older group head, the hole seemed pretty perfect and on yours it seemed kind of jagged?
