I am a new member and came across your site quite by chance following a google search trying to find a solution to my Isomac Millennium leak problem. You guys seem to be the right ones to ask so here goes:
My Isomac Millennium is approx 4/5 years old now and has never missed a beat in the past but recently we have noticed a pool of water collecting under the machine, even though the machine continues to show all the right signs and still makes great coffee, steam and hot water.
I took the top cover off the other day to check for any visible leaks but couldn't see any. I turned the machine on and left it for around three hours, made a few coffees and got no leaks. When I put it together again it was fine for the rest of the day but overnight, when the machine was switched off, we came down to another pool of water.
It is definitely not the plastic reservoir as we left that filled up away from the machine and not a drop was lost, so the leak is definitely somewhere in the machine plumbing.
Has anyone else experienced such a problem and if so can you help me with the solution please?
I look forward to a dry counter top very soon
Many thanks,
Paolo
