The idea for this mod came up in this post, the only real difference is that the "steam-valve" is now on the cold water side of the boiler which makes the temperature easier to control.
I added a oil-filled pressure gauge and a manual valve to a Precisia (single boiler w/ PID, vibe pump, no OPV) as you can see from the picture. I had trouble finding the right parts, the best I can say is that it doesn't leak . . .
This mod was easy, cheap, and has made my espresso much better. It could also be done on a HX machine. I'm not comfortable enough with my technique to do any 'research' with it, but others who are would be able to follow and contribute to threads like Greg Scace's pressure profiling one. If enough people do it we could get some Distributed Espresso Profiling action...
The Precisia doesn't have an OPV which was making for some very upsetting early mornings! This first video shows what happens when you combine a 15 bar pump, a tight grind, and poorly fitting PF gasket.
In the second video I held 9 bar* for 30 seconds. *not necessarily 9 bar at the top of the puck
In the third video I held 9 bar for 15 seconds and slowly reduced the pressure for the next 15.
This mod has made my cheap machine into one that I can trust, but on a better machine (with an OPV)... I think it could be really awesome!
Henry!
