The only issue I have is that the process is very inefficient: ~110°C water coming out as some 100°C hot water along with a lot of steam. The water is also too hot for our main use: green tea. We cool it off to 75-80°C (~175°F) by moving it through two different vessels before infusion. Wasted electricity to heat water, wasted electricity for the air-conditioner to cool down the excess heat.
I've looked at the setup of the GS3 mixing valve but I can't easily figure out the exact water flow (see this thread, for pictures).
From page 6 of the GS3 parts catalog
I'm considering the addition of a hot water mixing valve to my Vivaldi to cool water to a more reasonable / practical temperature. The machine is plumbed-in and uses a solenoid valve for hot water. It uses plastic tubing, which seems ideal to do the mod (provided I can get the correct parts and fittings).
Am I correct assuming this is a working setup?
I assume:
- A check valve is needed on the cool water side to avoid water from the steam boiler to flow back to mains? (not really possible as mains is at 2.5 bar and steam boiler at 1.35 max) Useful? Only as an additional safety?
- A check valve is needed between the steam boiler and the mixing valve, else water would flow from the mains (2.5 bar) to the steam boiler (0-1.35 bar), making an instant mess.
- I can find a spot to localize the additional parts inside the S1, ideally with quick access to the mixing valve (behind drip dray for example).
Questions:
- How do I make sure hot water at 1.35 bar stills comes out through the mixing valve while the incoming cool water is at 2.5 bar? I'm missing something....
- Do I need a thermostatic mixing valve, as the steam boiler pressure can vary, to keep a constant final water temperature (cool water pressure is regulated).
- Where can I find such a mixing valve?
- Any idea where I could procure the correct parts?: connector to the S1 plastic tubing (out of steam boiler, back to hot water solenoid), Y between cool water mains and F-o-T pump inlet, inter-parts connections between the additional parts, check valves, Y, etc.
- Any worries to keep in mind to avoid a big mess (I'm already protected by an automatic mains shut-off in case of water leaks) or equipment damage?
