Mini Grimac pumps slowly - scale problem? - Page 2
Postby rfc on Thu Aug 25, 2005 8:38 pm
Thanks. I am suspecting the water jet breaker. After 10 or 15 seconds, I get paltry amounts out of those four holes, and sometimes it only comes out of one or two. It should be gushing.
I just need to figure out a way to make a spanner wrench. Mine does not have a slot. It's four 1/8 (approx) holes on about an 1-1/2" center. It's probably a special tool that fits up there and unscrews it.
The only bothersome part is that with the cover to the "infusion device cap" off, I don't get much water out of there either. I'm getting close. I want to smell the coffee!
rfc
Postby HB on Thu Aug 25, 2005 9:15 pm
Does your water jet breaker look like this (rightmost)?
If so, I need to read more carefully next time. That's the stock water jet breaker / pod adapter for my machine, La Valentina. While it's really helpful to have the special tool you mentioned, I coaxed mine out by gently tapping a cutoff nail inserted in one of the holes. Later I replaced it with the standard E61 dispersion screen.
PS: If you removed the big bolt on the side of the group capping off chamber 14 and water didn't gush out, you need to look higher.
E61 patent diagram - modern versions are almost identical
Postby rfc on Thu Aug 25, 2005 9:28 pm
In the meantime....I applied a fine wire to the four holes and also used some compressed air to shake things up and now get a nice flow--probably in the neighborhood of 1.5 cc/sec at zero pressure.
I'll call this patient "stable" and won't let 'er out of the ICU until I can completely disassemble the group head, but will call this a success.
Threw some coffee in the portafilter and for the first time ever, pulled a double with blonding right at 30 seconds. Not much for taste, because the grind was not fresh, but I am on my way to the hard part now....learning how to do this (make coffee that is).
Thanks for all the help and ideas. :)
rfc
Postby rfc on Fri Aug 26, 2005 6:32 am
HB, thanks for the tip about the nail. I should have been able to figure that out. I used a center punch and got the water jet breaker (which looks like the big one in your picture) off and there was a lot of nasty stuff in there. Not so much like the sand I found elsewhere in the machine, but just "coffee sludge".
I think now that the entire water path has been cleaned, I need to focus on getting all the old coffee stuff off the grouphead.
Thanks again.
rfc
Postby HB on Sat Aug 27, 2005 3:29 pm
Good to hear you're up and running. By the way, if you haven't done so already, check out the Buyer's Guide to La Valentina. It's got a lot in common with your machine.
For future reference, I retitled this thread to match the actual topic. Returning to your original question, the thread roasters poll nominations is a good place for coffee recommendations.
Previous
Return to Espresso Machines
