Thanks Jim for your helpful instructions.
I ran the extarction again and found that the pump seems to stop working(or slow down, 'cos the vibratory noise become very very low) while the pressure raises to approx. 8.5-9 bar during extraction.
And consequently the brewing pressure drop down to 5-6 bar.
This time, after stay 5-6 bar for about 5 sec., the pump active and the pressure raise to 9 bar and then drop to 6 bar again.
There's little water flow back to tank during extraction.
Then I replace the portafilter with blind basket.
The brewing pressure raise and stay at the setting value.
The pump slowdown, and little water flow back to the tank.
Thus I remove the pump and disassemble it.
Please see attached picture.
I removed the OPV as well and found it seems to be normal(no clog).
Should I replace the pump with a new one?
