sweaner wrote:I wonder if anything can be done to raise the boiling point of the water, such as addition of extra minerals?
Not to pick on Scott too badly....but it seems to me that the focus has shifted away from the device itself and devolved into a conversation of water temperature and heating techniques.
Not there is anything inherently wrong with this, but the Mypressi device makes very nice shots just the way it is. I played with some temperature gymnastics to try getting a few extra degrees hotter but found myself going through alot of extra effort with no improvement in the cup.
My best shots so far have been the simple ones.
Here's the process that has yielded the best results for me (so far):
- Boil water in the electric kettle and pour some into my cup and fill the chamber (while the chamber is seated loosely in the handle). Leave the lid on the chamber.
- Prepare the basket: grind a measured dose, distribute evenly and tamp
- Come back to the kettle and boil again - since it's already hot it only takes a minute (or less)
- Remove the chamber from the handle and dump it out, along with the cup preheat water
- Place the loaded basket in the handle, install the chamber.
- Fill with water (the kettle is at a rolling boil)
- Replace the lid and pull the shot
The Mypressi apparently does an impressive job of "taming" lighter roasted and bright espresso blends. As an example, it made the best shots of the day for us when we were attempting to test grinders using a blend that was too bright and sour when brewed on the GS3. On the GS3, we started at 203°F and dialed all the way down to 195°F but the shots from the Mypressi (presumably) at 185-ish were markedly better.
So, my suggestion is to put away the thermocouples for a little while and see if you like how the coffee tastes using the device with just a simple preheat and boiling water just before the shot.
