Leaving espresso machine while on vacation
- wrz0170
I will be going on vacation shortly and as much as I would love to take my machine, lugging 60lbs in the suitcase might slow me down a bit.
Do many of you drain the boiler/water tank and unplug your machine? Not keen on 10 day old water just sitting there. Most likely give it a backflush cleaning too.
Well when I leave for greater than 7 days I switch off my gs/3. Otherwise it's on 24/7. I wouldn't drain it before going.
Luckily the gs/3 has with pump hot water water so I can flush it easily.
- keno
No. I've got an HX machine and the water for shots does not come from the boiler, just comes direct from the tank via the HX. So I do not drain the boiler. Would probably rinse and refill the tank.wrz0170 wrote:Do many of you drain the boiler/water tank and unplug your machine?
Might be more of an issue for those with a DB. But even if I had a DB I still wouldn't drain the boiler. I would probably just flush some water through when I got back from vacation.
Ditto.
If your boiler is a few litres, you can easily flush it.
For my DB I run water from the group head (brew boiler) and run the hot water (steam boiler).
