Leaking Andreja Premium
Postby marfer on Mon Apr 25, 2011 1:00 am
Some newbie advice here...
Came home to find my Andreja Premium had leaked about 2 cups of water!
I preceded to take off the case and try to figure out what had happened.
I couldn't find anything, everything was dry? My clever wife grabbed the drip tray filled it up with water
and placed on a dry piece of paper towel. In a few minute the paper towel was wet!
We found one of the 2 screws that holds on the front plate of the drip tray was loose and leaking water.
So... don't panic when you have a leak, check your drip tray, or better yet remember to empty it out
when you're done.
Matt
marfer
Postby cannonfodder on Mon Apr 25, 2011 9:00 am
VBM's will do that as well. The drip tray handle is attached to the drip tray with two screws and there is no rubber washer in there. Just a screw, lock washer then through the drip tray. When the water level gets over the screws, it will drip as you discovered. You could try taking the screws out, put a small rubber washer on between the screw and drip tray. That may stop the drip, or at least minimize it.
cannonfodder
Postby hudsterboy on Tue Apr 26, 2011 5:46 pm
My andreja sprung a leak once. Couldn't figure it out, and was about to panic when I realized that I hadn't put the return tube back into the reservoir.
hudsterboy
Return to Espresso Machines
