Long term followup:
Because of the way the lower panels (below the drip tray) are mounted to the frame, I decided not to make any cosmetic changes. Fortunately, we moved to a new house with a finished basement that is perfect as an espresso bar and adequately hides the hideousness of my machine.
I did add the PID to the boiler and it quietly and effortlessly does its job. During the winter months when the water is cold, I have it set at 239 F. During the summer months I drop it down to around 233 F. This gives me a max temp (after the requisite flushing) at my group head thermocouple* of about 205 F. If that tune-up kit is ever realized, I will do more controlled analysis and report back. I have the sense, that the machine is thermally stable. But I am fearful of saying so without charts and graphs and .CSV files.
*Going off of Eric's e61 thermosiphon thermocouple thingie, I decided to do the same thing in the group on my machine. I drilled out the 17mm bold that gives you access to the gicueler and group filter and mounted a type T thermocouple inside then used some wet JB weld to seal it up. I then hooked up a watlow PID with 1/10ths of a degree F readout. It works fine and gives me exactly the information I want which is a repeatably accurate view of the water close to where the coffee is made.
I have continued to experience some problems either with some part of the electronics, the capacitor for the motor or some wiring. About 60% of the time, when I push any button (auto or manual) that should enable the pump and open the supply solenoid, only the supply solenoid opens, no pump. Usually the first time I press it, the pump engages and I surf the group temp up to a temp that I think is right. Then when i load the portafilter, the second time I press, the pump wont engage, but I can use the line pressure to preinfuse then do a quick on/off to engage the pump. This is annoying at best and I have had "professionals" check the machine for weird obvious electrical problems and nothing has been found. If it gets worse, I will either scrap it or buy an external motor and reroute all the pump stuff to underneath the counter.
I was never happy with a standard 14 gram basket because of how far the dispersion screen protrudes into the basket when you mount the PF. At one point, I removed the dispersion plate, but this yielded too much headroom. Then the "synesso" 18 gram basket sell-a-thon came to HB and now I have what amounts to a new standard basket for the CMA machines.
Overall, I think the machine is a workhorse for home use. I dont drink milk, but I do make caps and lattes for friends. The steam power of a 5 liter boiler (even at the relatively low temp I maintain the boiler) is quite impressive. The stock nozzle sucks, but I have never changed it because, well, because I dont drink milk. I can pull back-to-back shots until the cows come home. I have never had the water temp not catch up. FWIW, I never pay much attention to the brew/boiler pressure gauges. The brew pressure is jumpy during brewing and I really dont trust that they are correct. Again, when the tun-up kit comes around, i will probably adjust as needed.
The bottom line is I almost never pull a sink shot that isn't caused by my choice of coffee. Some SOs just suck as espresso or some coffees when pulled too soon after roasting are super finicky and channel like crazy or just do weird things. But as far as the machine goes, they can be picked up so cheaply on eBay that if you are mechanically inclined, these are great machines to own. That being said, I am going to buy a GS3, if they ever materialize in the US.
