by kanoyu on Mon Feb 26, 2007 2:43 pm
edwa,
One of the challenges for me has been the (lack of) consistency, or repeatability, of what I observe my machine is doing. This morning, for example, I followed the protocol that I outlined to you, got no hump (from the tc device), and went from 205.7 deg F to 203.8 deg F at a fairly regular pace (didn't record, so I don't know how linear). Good pour, nice crema, rich taste at first, followed by an unpleasant finish--may have soured on me (or it could just be OLD coffee!). In terms of variance between tc device and Scace, even that varies, as Den mentioned, during the the shot (intra-shot), but also (for me) from shot to shot (inter-shot). For example, I will get greater intra-shot variance on the first pull, and less intra-shot variance on the next one (30 seconds later). I suppose it could be that the Scace device is already super-heated from the first pull. I also get greater stability with successive shots (as registered by the tc device).
Taking a chapter out of other postings concerning method, try to work on one thing at a time. If stability is what you're after, focus on that. Might I humbly suggest the following:
- give your machine plenty of time to warm up
- prepare 2-3 baskets with the same coffee, weight, grind, dose, and tamp
- flush to target temp (on tc device), say 205 (if 4 deg F is your variance, 201 maybe good to shoot at)
- lock first basket and wait 35 (or 40, 45, 50-but try to be consistent) seconds
- pull shot and observe temperature fluctuation
- use the next 35 (or 40, etc.) seconds to remove portafilter, remove basket (helps if you have ridgeless or no spring clip), and lock second basket
- pull second shot and observe temperature fluctuation
- use the next 35 (or 40, etc.) seconds to remove portafilter, remove basket, and lock third basket
- pull third shot and observe temperature fluctuation
Don't worry too much about watching the pour, focus on temperature stability (if that's what you're after). Once you have your routine down, you can check the pour out. Also, there will be a lot going on, so you might want to video the thermometer so you can check it later (unless you have data logging and plotting capability).
It might be easier, and you'd burn through a lot less coffee and water, if you had a Scace, but I'm not sure it would give you any more information on stability. Once you have addressed the stability issue (and I hope you will meet with success here), then you can adjust flush amounts to zero in on temperature (tc device reading relative to taste).
Finally, if I had been nearly as methodical as I am suggesting, I probably wouldn't have struggled as much as I did (am?). I'm sure you will be wiser than I have obviously been.
BTW, that's exactly what I do with my flush water!
Good luck.
dw
