Hi, there.
As I'm restoring an Oscar, I could add something here. The neplax valve at Oscar's group doesn't open even around 14 bar. This valve is new, the pump is old.
I've added an adjustable OPV but can't say anything about improvement yet. But I beg to differ from Dan - even at normal doubles the pressure rise to 12 bar (I've installed a pressure gauge and considering the Ulka pump specs, that makes sense). But as far as I remember Andy's post, and I can't find the thread, the flow is not directly proportional to pressure - at some point the flow goes down, maybe because the higher pressure pushes more fines down the puck and the they restrict the flow.
A vacuum breaker is easy to fit, and it's just a convenience. About the power, mine is 115V, and the heat element is around 10 Ohms. But here the power line is 127V and I get more than 1500W and 12A, so the wires go hot! But 100 to 200W won't make such a huge difference.
And finally, about temperature stability, I've played with the machine and a Scace device and it's very hard to find a good routine, besides the fact that the temp profile is rising ramp, for instance from 92°C to 97°C! I've
added the flow restrictors they use at Musica and now the machine is much better... Easy to use, just a little flush to get 94°C shots, or 1 to 4 seconds more if you need colder shots. As far as I've measured, no more than 1°C change.
Márcio.
