HB wrote:Correct. For vibratory pump, slow flow => high(er) brew pressure, fast flow => low(er) brew pressure. By adding an over-pressure valve that discharges water back to the reservoir, the gross flow rate from the pump is normalized so the pressure is consistent, independent of the flow rate through the brew head.
Well, let's see if I get this right :
let's assume a double is 60ml pulled in 25s : according to the pressure/flowrate chart, it would need at most around a 12bar pressure (60ml/25s = 140 ml/min which corresponds to around 12bar) -> so ~12bar is fine for doubles.
At this pressure, it would take half that time (12sec) to pull a single.
To pull 30ml in 25s you'd need a flowrate of ~72ml/min which corresponds to around 13bar).
So is it correct to assume that we want 9bar not for the flowrate (which is then more than sufficient) but because it is assumed it's the optimal pressure for (taste-wise) good extraction ?
If you've got an OPV set to 9bar, for a single, you'd have water redirected to the reservoir.
The question is then : what's the flowrate *after* the OPV ? How could that fit both single and double shots ?
As a matter of fact, if ~25s extraction time is set, you have to have different flowrates, one for singles, another for doubles ?
Or are we supposed to have 2 OPV settings : one for single shots, one for double shots ?
