In the interest of full disclosure I already own a VII (and love it) but without the latest preinfusion feature so I thought it would be a good test to do a side by side - literally!
I put both machines on the same water line with a tee and just switched them on one at a time. I only have one dedicated 20amp service installed in my kitchen for the VII. I adjusted to group pressure to 9 bar which is what I run my other machine at and the intake at 35psi. Set the temp to 94 and offset to -1. I don't have a Scace so this was just a swag.
First off preinfusion takes a little getting used to. I usually rinse my bottomless portafilter from the group prior to dosing. I also do this to get the group heater to kick in. Waiting for the group to preinfuse here is a bit of a pain. One suggestion would be to allow one button to be programmed with preinfusion and one without. That would make it easier to rinse.
I read Ken's preinfusion tests, at 35 psi I probably haven't got enough pressure for a full puck saturation. I'll crank it up again on my next round. I did try three different settings. 0sec, 3 sec and the full 8 seconds. I was using Black Cat from Intelligentsia. One I'm pretty familiar with. Again, not much science here just some observations. The 0 sec pour matched my other machine a nice balanced shot, strong chocolate base notes with a hint of caramel. The 3sec preinfusion added a brighter note - I though I could pick up some more berry flavors. The 8 sec pours consistently ran a little fast and blonded early. I think I will need to crank the grind down on these ones to get a better profile. The ones I pulled were a little sour. I've taken a shot of each pour at about the same time into the pour. I would note that I generally get a camel back (two bumps) on the start of my Vivaldi pours which went away with the preinfusion.
0 seconds preinfusion
3 seconds preinfusion
8 seconds preinfusionI picked up some Misty Valley espresso from Counter Culture Coffee today. I'm anxious to see how that fairs with the preinfusion. I'll also crank up the input pressure abit as well.
3 seconds
6 seconds
8 seconds
