La Spaziale pod adapter versus regular setup
Postby movnmik on Sun Feb 14, 2010 7:21 pm
It seems that I have too much time on my hands because I started working on the Rapid EK I picked up around the same time I got the Cimbali. Fortunately it was working and it really only needed a thorough cleaning and replacement of gaskets. I was just cleaning the groupheads and brass shower disc and was wondering why the new shower screens I just purchased looked different from the old. I purchased the correct part (checked and double checked). I then started to do a thorough search of LaSpaz groupheads and noticed this link
http://www.home-barista.com/s1-buyers-g...mance.html and low and behold my brass shower disc looks like the one at the bottom of the page. It appears to be a pod adapter shower disc. It also explains why the shower screen was much smaller.
This brings me to my questions
- Can I use the pod adapter brass shower disc? It seems like replacement shower discs are about $50 a pop and would like to not have to replace them.
- What order do the replacement shower screens attach to the brass shower disc? It seems that the smaller (with recess) would be closest to the nut.
BTW here is a link to see shots of the restoration
http://picasaweb.google.com/Movnmik/LaS...storation#
Brass shower disc
New Screens
movnmik
Postby HB on Sun Feb 14, 2010 7:39 pm
movnmik wrote:Can I use the pod adapter brass shower disc?
No, they're not the same. Here's the pod adapter and basket:
The regular diffusion block and dispersion screens are shown below:
The pod adapter sandwiches the pod between its small diffusion block/screen and basket. The regular grounds diffusion block and dispersion screens wet the full surface of the puck. A pod adapter pressed into service with regular grounds would pull shots that are more prone to channeling.
See above, they're installed in the order shown left-to-right. Details in the Buyer's Guide to the La Spaziale S1 (updated for the Vivaldi II).
Postby movnmik on Sun Feb 14, 2010 11:56 pm
Dan,
Thanks for the clarification.
Now I have two La Spaziale pod adapters to get rid of :(
movnmik
Postby JmanEspresso on Mon Feb 15, 2010 12:28 am
The Brass Dispersion Block, for ground coffee, at $19.95 from Chris Coffee. I just bought a second one on Wednesday.
JmanEspresso
Postby movnmik on Tue Feb 16, 2010 12:51 pm
Jeff,
Thanks for the info.
I want to commend Chris. After Jeff's response I went on to CC's site and initiated a web contact. Chris replied within an hour and indicated that I should give the service area a call. I called later that same day (yesterday) and ordered the parts. I got the parts today. I personally experienced why people recommend Chris Coffee so highly.
Mike
movnmik
Postby movnmik on Tue Feb 16, 2010 5:17 pm
Wanted to add that San Marco Coffee is another supplier of La Spaz parts and has very reasonable prices and s/h costs. FYI for all you La Spaz owners.
movnmik
Return to Espresso Machines
