by jn_nz on Sat Dec 18, 2010 10:28 pm
Hello folks,
I'm usually in the lever part of this forum and have never worked with pump machines. I'm investigating on behalf of a friend with a Butterfly machine. (This is an HX machine right?)
She's not technically minded so I'm having difficulty getting straight detailed info from her. From what I can tell, right now she's having her pressure valve blow when she leaves her machine on but she's also noticed before this started happening that her steaming power was diminishing.
Her pstat was replaced by the service agent. Her pumps are good, but she's still having trouble. I think she backflushes as often as recommended but from what I gather she had no idea she needed to descale her machine. Could this be the source of her trouble?
I think she needs her pstat turned down, i can do that for her, but i don't think she can do this right now without killing her steam performance.
The machine is at least 2-3 years old so probably in a bit of a state by now! Now if she descales, she risks getting flakes of scale into the group right? How can she avoid this? Should she not run the descaling solution through her grouphead? There's no way she's ever going to take that apart for cleaning herself if she gets loosened crud in it and it starts leaking. I don't want to recommend a course of action that's going to land her with extra maintenance expenses if I can help it. Also taking the machine apart for an acid batch etc is probably out of the question.. if that's what's required I'd have her take it to her agent. (ie: I don't want to be responsible for her machine!)
In this machine, how does she get descaling solution through her steam wand? I read something about tipping the machine 45-deg left and then right to overfill the boiler. Does this work?
Is there a quick way to drain the boiler to speed up getting the descaling solution into the boiler form the reservoir?
Is there anything else I need to know or consider? The machine is technically brewing just fine so I'm guessing all the electronics are functioning as they should. The service agent was talking about replacing the logic board at vast expense, so I'm trying to save her wasting that if its just overdue for a damned good clean.
Thanks in advance.
