I get the whole thing assembled and start pushing water into it. A couple leaks here and there at fittings - all fixed with a quick twist of the wrench. Everything seems fine except for a small noise of moving water... but there are no leaks that I can see. Looking, looking - can still hear the water moving. I turn off the valve for the boiler fill. Still a little bit of noise.
About 3 seconds later the overpressure valve and the antisyphon valve start spraying water all over the basement. Turns out that there is a leak in between the removable thermosyphon into the boiler. I have traced it to the lower/front connection which is, by matter of luck, the most complex and difficult to access.
So if someone has loads of La San Marco experience - please offer me some advice. Otherwise, you can take a look inside a small commercial machine.
Here is the view from the back of the machine. I took a wire wheel and polished all of the mating surfaces in the hope of solving my problem which it did not. I re-assembled it and it still leaks.
Here is the view of the inside. These are simply holes stamped in the flat sheet that makes up the boiler. You squish these areas flat when you tighten everything up.
Here is the view from the front. That thing with the big screw is an expansion valve. It opens to let water out when when heated in the thermosyphon.
Here are the parts out of the machine. This is not a mechanically simple thermosyphon to work with. Replaceable - yes. Simple - NO. Lots of threaded joints. Lots of gaskets. Hard to tighten/loosen when in the machine.
WES
