www.zokacoffee.com: you're original, drink like it - single origin & artisan coffee
La Pavoni P67 rebuild
Postby craigcharity on Mon Sep 05, 2011 2:16 pm
Hi there guys
This is way over due but I thought I would share some of the photos of my La Pavoni P67 rebuild.
Let me take you to the beginnings:
I got it from our local Junk Mail website, I usually search these for ; espresso, coffee machine, coffee grinder etc but sometimes I type in 'espresso' just to see what comes up and this time I hit some luck. I bought it for R750 which is now about 90 or so USD.
Here are some of the strip down, I didnt have anyone to help me carry it to my back porch so I did this on my driveway and front porch:)
Here is some of the scale from the boiler- O forgot to tell you, the guy I bought it from said it was working:)
craigcharity
Postby craigcharity on Mon Sep 05, 2011 2:24 pm
I had the frame sand blasted and coated in an epoxy, I didnt know it would be blue, I sprayed it black later.
I had some new springs made, I calculated the force I needed and had a local company make them. I searched high and low but couldnt find them, I later found out that it was a standard size spring that the new LP use as well as astoria etc.
here is what they looked like after being yellow passified. I found out that they began to get some surface rust so I took them to a mate who does electro-plating.
He also soaked all the copper and brass parts in some solution and then in a brightening solution to retain their shine, worked like a flipping bomb, shows you what pro's can do:)
craigcharity
ancap-usa.com: quality Italian porcelain coffee serviceware in the USA
Postby craigcharity on Mon Sep 05, 2011 2:32 pm
Here are some of the pics of the re-assembly:
I chose to re-pipe the machine since the other copper pipes looked terrible, I had to get some brass fittings to do so.
I have to go now, I will upload some more tomorrow.
Cheers for now, hope you are enjoying the photos.
craigcharity
Postby RayJohns on Mon Sep 05, 2011 5:05 pm
Beautiful work!
Ray
RayJohns
Postby JY on Mon Sep 05, 2011 9:04 pm
Nice!
-Jim
JY
Postby Chert on Mon Sep 05, 2011 11:48 pm
Looking forward to seeing more!
Flint
LMWDP #189
Chert
Postby allon on Mon Sep 05, 2011 11:56 pm
Beautiful!
Any thoughts to adding a vacuum breaker?
Also, are this piston seals on correctly?
LMWDP #331
allon
Postby craigcharity on Tue Sep 06, 2011 1:12 pm
Hi Again
I did add a vacuum breaker in the end, and yes the seals were on wrong:) I re-fitted them after I took the photo.
craigcharity
Postby craigcharity on Tue Sep 06, 2011 1:23 pm
Here is my first shot
I hadn't even fitted the drip tray as there was no place for it to drain in so I put a container under the group so I could pull a shot. It was the best shot of 'Nonmara'( the blend that I use for my mobile coffee bar business) that I have ever tasted.
Here are some of my shots once I had dialed my grinder in and set my pressure stat:
craigcharity
Postby napierzaza on Wed Sep 07, 2011 4:44 pm
Lever machines are amazingly simple. Very nice.
napierzaza
Return to Espresso Machines
