godlyone wrote:issue 1: the brew boiler should be filling anytime there is incoming mains pressure. for the steam auto-fill do you hear the solenoid click? can you measure the voltage going to it to make sure it kicks on? Also I believe that solenoid has a specific orientation and is "1-way"
issue 2: I'm not sure, but I would contact the part supplier - maybe it's the wrong part?
issue 3: this is bad, maybe there is a way to just weld the whole group to the boiler?
1: No click when the on\off button is in the fill position, though I did realize the valve was reversed, but even after fixing that, nothing happened. The manual fill button on the machine works fine though, so I'm assuming it has something to do with the Brain. I think at one point I remember reading you can "jump" some pins to turn autofill on or off or something like that, but I gotta dig more.
2: I send an email to EP. The O-ring is large enough to go over the entire Chrome ring, when it should nestle in behind the Glass, and in front of the Brass fitting. (I think)
3: I THINK the bolts are silver soldered on... But I'm not 100% sure. I have a really good welder friend, just hoping someone has had a similar issue and may be able to help with other ideas. I'm at a loss, I'm 100% running, and appearing to run well, but these issues are killing me.
I thought I was a patient guy, but this machine may have proven me wrong, haha. "Live and Learn"
