La Marzocco Linea Pressure Gauge Issues - Page 3
Postby Mac18 on Mon Sep 05, 2011 9:54 am
The pump is a fluidotech PA01504 http://www.fluidotech.it/Pages/en_po_500_1000.aspx . I have to check the motor when I'm at home.
Mac18
Postby erics on Mon Sep 05, 2011 11:33 am
Well, with the bypass completely shut (typical factory test point condition), that pump flows 184 l/hour or 3067 ml/minute at a 9.0 bar setpoint. I'd say that the bypass is quite active with your machine and with anyone else's. :)
It does appear to be the specified pump for your machine and the very high flow capacity is meant to minimize shot pressure variations when a boiler fill signal occurs at this "inopportune" time.
Skål,
Eric S.
http://users.rcn.com/erics/
erics
Postby Mac18 on Mon Sep 05, 2011 11:41 am
Hmm, is there a way to adjust the bypass? Tr
Mac18
Postby erics on Mon Sep 05, 2011 4:59 pm
If you simply press the continuous brew button and adjust the pressure regulating screw (bypass) on the pump to show a pressure of 9.0 bar while the water is flowing, you will be "in heaven". As I type, yours appears to be correctly set.
2887 ml/min are bypassed within the pump itself from the discharge side back to the suction side at a discharge pressure of ~ 9.0 bar when brewing espresso. The numbers are, of course, subject to normal production tolerances and brew preferences - say +/- 5%.
Skål,
Eric S.
erics
Previous
Return to Espresso Machines
