by NickA on Tue Dec 29, 2009 7:16 am
My Linea 2AV masked control box has recently started playing up. The single shot (far left) button no longer lights up if you press it. All the other volume buttons work, and both left and right groups are the same. I turned the machine off for a few minutes and tried again, and the single shot button worked, but the next time I used it it was off again, so it is intermittent. I have tried reprogramming the times, and once again all the otehr buttons respond as they should. If you try to program the single shot button, when you press it to start, no water flows, but when you press it again to stop the shot, the light goes out as though it has been programmed.
I have repaired electronic devices before so I'm equipped to work on it, but I would appreciate any pointers I can get before I start. Does anyone have a circuit diagram of the Gicar masked box? Does anyone know if there are 8 separate circuits? (1 for each shot time x 2 for 2 groups) If so it seems surprising that both single shot circuits have gone at the same time.
Any help would be appreciated.
