La Marzocco - Linea 2AV - Rebuild - Page 3
Postby Euology101 on Wed Jul 06, 2011 3:08 pm
jpboyt wrote:You can run all manual functions without the control box being plugged in but it takes a jumper between pins 9 and 10 of the 12 pin female connector. Easiest way is to move wire from 9 and pair with 10 at the connector. If you look at the schematic on the cover you will see that is what Gicar did internally on the board. Just off the top of my head I think that pin 9 has a white wire and this is where everything that runs off of it is sourced from. Not a bad way to test things or run your machine if the control box is out for repair. Older mask and non-mask controllers don't need the jump.
jpboyt
I see in your signature, that you have "Circuit boards" listed as your equipment, does that mean you service them if mine has an issue? :D
Glad to hear that bit of knowledge, though, that could come in really handy, if the brain needs to be replaced.
Euology101
Previous
Return to Espresso Machines
