JWPATE wrote:Yes, I believe the laser-cut story was probably invented. I really doubt the machines left Florence in that condition. Also, the drain tray had the identical protective film and the same laser cut pattern, but that film was not burnt. I still suspect care-free testing in Seattle caused the burnt on film.
That is normal for the laser cutting to do that and obviously the protective film stays on during cutting and bending and until it reaches the end user. It would be abnormal to have a machine without any film but maybe it was removed for another reason.
Even still, if the benchtesting had caused the film to stick (which takes a very long time) it is a good thing in the same way that coffee grinders have coffee in them or machines have water drops in the pourover tank or oils on the group screen. It means it has been tested. Sloppy, but a good thing.
