by Peppersass on Thu Sep 08, 2011 1:59 am
I installed the new-style vacuum breaker a couple of weeks ago. I'm not completely sure, but I believe the valve seat has a teflon coating to resist mineral buildup, which should reduce the frequency of maintenance. The breaker also has a 90-degree hose barb from which a tube can be run to the drain box. This prevents any water or steam exiting from the valve from getting inside the machine and possibly dripping into the brain box.
The parts diagram shows a barbed termination fitting for the tube that passes through a hole in the frame above the brain box near the drains for the steam and coffee boiler OPVs. Rather than drilling a hole in the frame for the fitting, a T-fitting can be used to connect the tube running from the vacuum breaker to the tube running from the steam boiler OPV.
The retrofit is relatively easy if you have the proper metric tools. I took photos of the installation and will post them soon.
I highly recommend this update to owners of GS/3s with serial number 1169 and earlier. You should be able to order the kit from your dealer.
As for the anti-vibration kit, it's my understanding that it can't be retrofitted to older machines because the pump won't clear the left side panel. Evidently, the chassis cutout for the motor was relocated to accommodate addition of the bushing.
I "outboarded" my pump and motor to completely eliminate noise and vibration. I also added a motor on/off switch for manual line-pressure preinfusion. Removing the motor from the GS/3 is a major undertaking, so I bought a spare motor and just relocated the pump. I have photos of that project as well, and will post them when I get a chance.
Dick Green
