To distill this problem down to its essence, there were a large number of these machines that sat in a warehouse in Seattle for more than a year after they were built, and many of these machines have been sold recently under the "fire sale" at reduced prices. I got one of those, which was built 14 months before I received it recently. Noise and vibration problems on GS3s have been widely reported, and appear to be even more common in the machines that have been shipped out recently. This post gives a suggestion for work that you might do on your machine if you have noise and vibration problems. At the bottom of the post is a disclaimer in bold type; please read this before acting on any suggestions you see in this post.
There are 3 motor mounts on the pump motor, two of which have been implicated as having been overtightened (the two on the left side, shown in a picture on the gs3cafe thread). The mounts use a piece of rubber to dampen the vibrations and if the nuts are overly tight, the rubber does not dampen the vibration. Instructions from LM have been to reduce the tightening on these nuts and to spray silicone spray around them. The image below was stolen off of the gs3cafe thread, with the yellow arrows indicating the positions of the motor mount nuts:
I did this above procedure which seemed to help a little bit however after a few days the noise and vibration returned and in fact got much worse. It sounded like they were using jackhammers on the street in front of my house each time I pulled a shot, it was that bad!
I tried several times to get ahold of someone at LM recently however this time around I was unsuccessful for days and finally decided to find my own solution. Examination of the machine in operation with the left side panel removed showed that without question the vibration was coming from the outflow braided water line, which goes from the left side of the rotary pump as you face it and clearly visible on the above picture. This line, if too taut, transfers all the vibration from the pump and motor to the chassis via the brew boiler.
Here is how I solved this problem****: with the cup tray removed (it is friction fit and removes easily), use a long screwdriver (either Philips or blade shape) and loosen up the screw holding the clamp between the pump and the motor. There is a hole in the top case that will easily admit your long handled screwdriver that will reach this screw. Once loosened a bit, you can rotate the pump on the motor so that the braided water outflow line is no longer so tight that it is held tightly on the front of the brew boiler. If the braided line is too taut on the brew boiler, you will presumably need to rotate the pump in the clockwise direction. You need to be sure that you have not put the rotary pump in a position where it contacts other things such as copper water lines or the case. Once you get the pump rotated so the water line is no longer tight on the front of the boiler, and that the pump itself is not in contact with other internal components, retighten the screw on the motor/pump clamp.
In my case this completely eliminated the vibration and noise problems other than for a little bit of vibration on the drip tray, which I'm going to solve with another suggestion made in a CG thread. That was to buy a small amount of a self-sticking material called "Dynamat" (available on ebay as 2 square feet for $13 delivered) to put at contact points between the driptray and the machine's frame. Doing this should eliminate any remaining noise and vibration in this machine.
Ken
****Please note: The above suggestion requires working inside of a GS3. DO NOT do any such work on an espresso machine with the machine turned on and plugged into an electrical outlet. YOU MUST turn off your machine and unplug it from the wall before attempting to do any work such as this, because you risk electrical shock and DEATH as a result. If you are uncomfortable working on an espresso machine DO NOT attempt this repair.
This repair has not been recommended to me by LM and is suggested by me with no guarantees whatsoever. I take no responsibility for any damage you may cause to your machine by virtue of your following these suggestions. Proceed at your own risk.
