La Marzocco GS3 Noise and Vibration Problems - Page 10
Postby wiz561 on Thu Feb 04, 2010 3:43 pm
By any chance, is there a maintenance manual for the gs/3? Does Chilton's make one? :D
I've heard of the infamous orange book, but it's for the Linea, not the gs/3.
wiz561
Postby boyscout on Thu Feb 04, 2010 6:40 pm
wiz561 wrote:By any chance, is there a maintenance manual for the gs/3?
I don't know about a maintenance manual, but just in case you don't know about these being on line:
PARTS CATALOG
INSTALLATION GUIDE
OPERATING MANUAL
boyscout
Postby Paul_Pratt on Fri Feb 05, 2010 7:57 am
shadowfax wrote:Jon, I might have a pump for sale on the cheap.... 8)
Seriously, though, Paul, I am surprised you say it took you that long. IIRC it was about 3 hours for me. I wouldn't argue that it's an extreme measure—it was a seriously fiddly, touch and go exercise that I wouldn't recommend to the non-mechanically inclined in the slightest; but I'm happier having it out of there. The machine is lighter, and there's more space in between the boilers, which left me extra room to properly insulate the steam boiler. Moreover, a new motor will cost you about $150 minimum here in the US (that's the best price I've seen, from Synesso—they sell a switchable 240/120VAC motor), so even if it did take you the better part of the day the effort is arguably worth it (unless you make well into the six figures at your day job, for example). Heck, I bet you could have it professionally removed for less than the cost of a new motor.
I seem to remember it was the main wiring box with the on/off switch that was a PITA. It was an early model (<#100) and there was not much room inside the box. I've been told that it has been changed and the box is more roomier inside. If I had to do it again for someone you wouldn't get much change out of that $150 :D
Paul_Pratt
Postby shadowfax on Fri Feb 05, 2010 3:22 pm
Yeah, but of course you have have to deal with the brain box whether you take the pump out or buy a new one, so it's hardly fair to include that... :P But, yes, isolating the pump cables from all the other ones coming into the brain box and then replacing that with a long cord was a tedious job that wasn't helped by how little wiggle room you get to pull it away from the machine because of all the short wires running back to the machine. For the whole job of outboarding, I'd sure charge at least $150 if it weren't for a good friend.
Nicholas Lundgaard
shadowfax
Postby JonR10 on Fri Feb 05, 2010 3:25 pm
shadowfax wrote:For the whole job of outboarding, I'd sure charge at least $150 if it weren't for a good friend.
Do I qualify? Does this mean you are offering to do mine? :mrgreen:
Jon Rosenthal
Houston, Texas
JonR10
Postby rbh1515 on Sat Feb 27, 2010 11:35 am
I installed the longer braided hose a couple of weeks ago. My GS3 has stayed very quiet. I think this is the fix. At the same time I re-lubed the motor mounts and adjusted the T-nuts. Occasionally I get a very faint vibration in the drip tray, but otherwise the machine is very quiet! I highly recommend the longer hose.
Rob
rbh1515
Postby EricC on Thu Sep 30, 2010 3:48 pm
EricC wrote:I have also put in a request with the importer here in the UK, Mulmar, to enquire about it for me.
Regards
Eric
Well Mulmar came through for me.
My longer hose, 54cm, plus several other bits and pieces arrived today. :D
EricC
Postby EricC on Sat Oct 02, 2010 5:58 am
Update.
As stated by Ken much earlier in the thread the original one i took off was 50cm long and the new one was 54cm long.
My GS/3 does now sound quieter and appear to have less vibration, much better.
At the same time I received the rubber group to boiler "O" ring, the one that surrounds the swan neck and covers the gap between it and the stainless bodywork. My machine had never had this since i received it, and once fitted really improves the GS/3 looks.
All in all, well worth waiting for.
EricC
Previous
Return to Espresso Machines
