by networkcrasher on Wed Feb 03, 2010 9:33 pm
Ooof. I outboarded, and I can't imagine doing a HowTo on it. The steam boiler just needs to be tilted back from what I recall, but I pulled my machine apart in the middle of the night. You essentially have to remove both sides, remove the top, the rear braces, pull out the control box at the bottom, disconnect the pump, (optional) remove the pump from the motor, cut the wires to the motor (or remove them from the control board). Once the motor is out, you need to make an umbilical from it back to the machine (I used an extension cord and had a male plug attached to the motor wires and a female plug wired to the main board). You'll also have to get the capacitor out of the control board box, and rewire that up appropriately.
It's not really that hard, but you'll have to sort of figure it out as you go. It's basically take it all apart, get the motor out, then put it all back together, then extend the pump wires.
Then the plumbing part comes in... Will have to find the appropriate fittings for the pump outlet up to the distribution block. Add to that custom making a bracket to hold the capacitor and the pump.
