Ken Fox wrote:My machine did have a very marked improvement in its noise problem when I rotated the pump, although after a couple of weeks a tiny bit of the noise was returning (and getting worse) and I can imagine having to do this maneuver every month or so as vibration undoes the "repair."
I've noticed this on two different GS/3s when I don't use cable ties. It doesn't take a couple of weeks to happen, though. Usually, I'll get the pump and hose oriented just right, the machine will be dead quiet for a few uses of the pump, then suddenly it'll be vibrating again. A few uses of the pump later, the noise will go away.
I don't think it's slippage of the pump in the motor clamp. I think when the pump kicks in, the hose moves around slightly. Eventually it makes contact with something that makes a racket. Further use of the pump reorients the hose again, and the noise goes away. The lurching motion of the pump that you see when the steam boiler is filling pulls pretty hard on the hose, so it may be the biggest contributor to movement. We use the tea water wand a lot here, so maybe that's why the change occurs more frequently.
Cable ties per the photos previously posted worked pretty well on my previous GS/3. A tie between the pump outlet and frame keeps the pump from lurching forward, and a second tie where the hose makes its turn from the front to the back of the machine keeps the hose away from the boiler. I haven't gotten around to installing cable ties on the new GS/3.
This new machine, by the way, has a much noisier drain tray. I'm pretty sure that's because I had been using the previous GS/3 in pourover mode until the very end, and the pressure of the spring-loaded tank against the drain box dampened the vibration. Now I'm plumbed in and the tray rings when pulling a shot. I'll probably have to go with some sort of damping material.
