networkcrasher wrote:As I'm outboarding my pump, I can't really try this anymore, but has anyone considered wrapping the short tube between the pump and mixing valve with some type of insulation? Maybe neoprene or the like?
I've been considering that.
Since I altered the position of the mixing block end of the tube, I'm getting periodic heavy vibrations. I'm in the process of trying to find a position for the pump and L-joint that eliminate vibration, but it isn't easy. I'll find a good position, then after I get the machine back together and run it for a while, the tube migrates and the vibration starts again. This reinforces Ken's observation that there's a very limited range of positions for the pump and L-connector that eliminate the vibration altogether (as was the case when my machine was new.)
I think a neoprene wrap might work and I believe it would be adequate temperature-wise. At Jetboil (shameless plug), we use neoprene to insulate the aluminum cup, which can contain vigorously boiling water.
