La Marzocco GS3 - Dispersion Screen Is Loose
I just changed the group head gasket and cleaned the dispersion screen. When I reinstalled the screen, the screw is tight but the screen is still loose. Thoughts?
Happened to me, too! It was with the IMS screen just a few months old. Wasn't sure if it harmed the shots or not so just replaced it.
1. Took off gasket.
2. Took off screen.
3. Put on gasket.
4. Put on screen.
Reversing 3 & 4 may do the trick if gasket is providing friction. I replaced an 8/9 mm gasket with a 6/7 mm which could be the problem. However, I thought the two were independent.
2. Took off screen.
3. Put on gasket.
4. Put on screen.
The problem was the thinner gasket. I put a new thicker one on, and it worked. There is an inner raised ridge that the screen seats against.
I don't like the thicker gasket, portafilter is at about 7:30 fully locked. There may be a different screen design I can try. I have a silicone gasket on order. Ppl who use them like them better than rubber. I would like the portafilter around 6:00 if possible.
If you really want it to be at 6 I think its possible to file down the portafilter ears so that it fits?
- uscfroadie
A better option for modifying your portafilter, if you absolutely MUST have it at 6 o'clock, is to remove the basket and sand the top lip; allows the basket to sit deeper in the portafilter. Very easy to do - just lay it face down on a flat surface with 1,000 grit sandpaper. Rub the portafilter (basket removed) in a figure 8 pattern, checking your fit along the way. Keep in mind that this is non-reversable.
Your other option is to just use the machine and portafilter as it was designed from the factory. It's not as if the portafilter backs out at 7 o'clock position.
Merle
- danetrainer
There are two sizes of group gaskets available, the LM have a conical shape and I believe the sizing is 6/8 & 7/9, if I remember correctly.
Sounds like a good idea! It did bug me for awhile when the machine was new but now that I've gotten used to it I don't really care that much anymore...uscfroadie wrote:A better option for modifying your portafilter, if you absolutely MUST have it at 6 o'clock, is to remove the basket and sand the top lip; allows the basket to sit deeper in the portafilter. Very easy to do - just lay it face down on a flat surface with 1,000 grit sandpaper. Rub the portafilter (basket removed) in a figure 8 pattern, checking your fit along the way. Keep in mind that this is non-reversable.
Also, it is less of a problem when I'm using the naked portafilter since you don't have the spouts being not parallel with the machine.
