La Marzocco GS Two-Group Rebuild
Postby Jeff on Sat Nov 19, 2011 12:01 pm
Well, I didn't really want to say anything until I actually had the machine in our hands, but the UPS man delivered a pallet yesterday. I'm told that this machine appears to have been imported by what was at the time called Visions Espresso Sales and Service (La Marzocco USA History), perhaps around 1980-1982. The early history of the machine isn't known, but it does seem to have escaped freeze damage and there isn't any obvious evidence of leaks. Pretty clearly not running, so our trustworthy Anita will be pulling shots for a bit to come yet.
Looks like this one has two steam arms instead of the cup warmer. Pretty "unique" steam arms at that. Neither is stock. The manometer, while nice, is likely not stock either (CMA Astoria #21100).
30-year aged coffee. Better for Scotch, IMHO
Nice lines on these old GS machines. Reasonably small for a commercial two-group as well, about 25 1/2" wide and will be around 13-14" high with the legs in place.
Looks like someone had problems with the auto-fill at one point.
Ummm, yeah, more evidence of some challenges ahead. The rust situation doesn't look unmanageable. I'll have to check under better light, but the frame on this one looks to be black.
Jeff
Postby allon on Sat Nov 19, 2011 12:06 pm
Wow. What an awesome find. Great potential there.
How'd you find this gem?
LMWDP #331
allon
Postby TomC on Sat Nov 19, 2011 3:02 pm
Pretty clean appearing for 30+ years!
Fresh out of the roaster: Hawaii Ka'U Typica, Ethiiopia Gedeo Worka, El Salvador Kilimangaro WP
Next batch: Nothing yet!
TomC
Postby terryz on Sat Nov 19, 2011 4:06 pm
Nice, if you need any help let me know.
Terry Z
Espressoparts.com
____________________________________
Much of espresso speculation is faith based.- Michael Teahan 2011
terryz
Postby Clint Orchuk on Sun Nov 20, 2011 12:30 am
Sharp looking machine. The older GS's are very cool.
Clint Orchuk
Postby Jeff on Mon Nov 21, 2011 3:02 am
The machine comes apart very nicely. I have to say that this is a cleanly designed piece of equipment, much like one of the "old school" machinists I once knew would have put together. There is enough room to work on the inside, yet things are tight and somewhat minimalist.
The auto-fill circuitry seems to me to have been added as an "option" based on the difference in wiring and how it was connected in. The electrical system is very simple:
  • Power to Sirai pressurestat feeding steam boiler (2300 W cartridge element)
  • Power to Fenwal thermostat in thermowell feeding brew boiler (1300 W, looped element?)
  • Power to three microswitches in parallel, feeding pump (two on the groups, one on the hot water valve)
  • Power to Gicar feeding Parker valve and pump
  • Red indicator in the "dash" not being connected to anything ;)
The loom came out in one piece pretty easily, in case someone wants to go back to stock.
The plumbing isn't that complex either. Here's the fill system.
The steam boiler seemed to have water in it even after I tried to drain it from the sight glass. The drain bolt (and the lack of water flow) was the first hint as to why.
Yes, apparently it has a scale problem. The steam boiler water nearly looked like fat-free milk. There is probably an inch of crud at the bottom of the boiler.
I'm still pondering the big 30 mm hexes on the end of the brew boiler. I think that will be an exploration when I'm not so tired.
Jeff
Postby gyro on Mon Nov 21, 2011 6:42 am
Cool project, hopefully it will be fun!
gyro
Postby vashonz on Mon Nov 21, 2011 11:22 am
Neat looking machine. Visions Espresso is still around, they're here in Seattle. I talked to the owner at a coffee festival earlier this year, from what I remember he had some pretty impressive machines.
vashonz
Postby Ronin on Fri Nov 25, 2011 10:29 pm
Funny how different the GS'S can be.
These photos highlight the differences between yours and mine Jeff.
Some plumbing, electrical and boiler differences and even the lever for the three way valve
Keep us posted
Ronin
Postby cannonfodder on Sat Nov 26, 2011 1:02 am
A big crescent wrench would work on those boiler bolts, or hit the auto parts store. Axel's and such use those big hex bolts and they usually carry them in stock. You could also hit sears but you should be able to get one for under $15 provided you have a 1/2 inch ratchet to use it with.
cannonfodder
Next
Return to Espresso Machines
