La Marzocco GS/3 valve releasing steam non stop
Postby misterdoggy on Fri Feb 25, 2011 12:16 pm
Hi All
I haven't posted in a while as there have been no worries. However, I shut the machine down for work in the house and placed the hot machine near a cold door which reeked havoc everywhere. condensation in the led readout and buttons and worse yet the cooled off boiler gasket shrunk down and permitted water to leak on to the motherboard just below. So... After drying everything out cleaning up taking apart and putting back together it works fine EXCEPT the pressure relief valve on the back boiler is not seating and releasing steam non stop.
Perhaps this valve has another name in Coffee Terminology, but I could not find a topic relating to it because I am not sure of its proper name.
My question is can this be fixed remedied or do I have to replace the relief valve with a new one.
I emptied the boiler letting the steam wand empty out all the pressure, with the machine turned off and restarted several times only to find the same problem. I can use the machine by turning it on and making a coffee, then turn it off to stop the constant flow of steam escaping ...
Any tips or hints would be greatly appreciated !!
thanks
misterdoggy
Postby tekomino on Fri Feb 25, 2011 12:41 pm
You can try taking it off (of course machine should be cold and not under pressure) and cleaning it and soaking for an hour in citric acid solution in case it got scaled up. If that does not help you will need another one. This is considered pretty much standard maintenance item.
Refuse to wing it! http://10000shots.com
tekomino
Postby HB on Fri Feb 25, 2011 12:56 pm
misterdoggy wrote:...it works fine EXCEPT the pressure relief valve on the back boiler is not seating and releasing steam non stop.
A photo would confirm, but I believe you refer to the vacuum breaker valve (a pressure release valve opens only if the boiler is continuously heating to prevent a boiler rupture). See What is the purpose of a vacuum breaker valve and Can someone please explain false pressure? If so, cleaning it as Denis describes with citric acid / vinegar should remove the dirty/scale preventing it from sealing.
Postby misterdoggy on Fri Feb 25, 2011 1:12 pm
thanks for these answers
i didn't know the term, I do in French Van Soupape :)
Here's the foto image of it Image
misterdoggy
Postby Marshall on Fri Feb 25, 2011 1:20 pm
Yes, that's the vacuum breaker, which is a normal replacement item on commercial machines, where they typically last a year or so. They are cheap, and I would just replace it.
Marshall
Los Angeles
Marshall
Postby misterdoggy on Fri Feb 25, 2011 1:24 pm
A replacement is in the mail...
In the meantime its easy to get to so I'll try cleaning the one I have. I took it apart and Voila there was quite a buildup of "calcaire" ...
I was surprised as i faithfully use a brita and change the filter every 3-4 weeks, on top of the fact that water here is not that hard to begin with...
Makes me start thinking about the insides of the boilers.
This site is the greatest. I tried to call my supplier and he was out, called La Marzocco but there were no technicians around, and then came here and got the response within the hour
Thanks Home-Barista !!
misterdoggy
Postby Marshall on Fri Feb 25, 2011 1:36 pm
misterdoggy wrote:I took it apart and Voila there was quite a buildup of "calcaire" ...
It might actually be salts or chemicals that your Brita system uses to soften the water. Particularly, if you regularly cycle your machine on and off, mineral residue will build up quickly at that point. Several of us had that problem.
Marshall
Los Angeles
Marshall
Postby misterdoggy on Fri Feb 25, 2011 2:04 pm
I cleaned it up got the calcaire off the needle, but there is a rubber ring joint at the base that has a "break" in it and it looks kind of tired as well.
It did nothing to stop the steady escape of steam
Oh well, patience is a virtue and I will have to try to be virtuous :) and wait for the replacement
With all thats happened with the motherboard floating in water and all I'm getting out lucky
misterdoggy
Postby Louis on Fri Feb 25, 2011 2:11 pm
misterdoggy wrote:i didn't know the term, I do in French Van Soupape :)
Vacuum Breaker Valve = Soupape casse-vide
Pressure Relief Valve = Soupape de surpression ou valve de sécurité
Louis
Postby HB on Fri Feb 25, 2011 2:19 pm
misterdoggy wrote:I was surprised as i faithfully use a brita and change the filter every 3-4 weeks, on top of the fact that water here is not that hard to begin with...
Really? I lived in Vence on the Côte d'Azur for awhile. The water there appeared very hard judging from boiling water (sorry, I did not measure it; the water left a distinct whitish rim of mineral buildup). On the plus side, the water tasted excellent and needed no filter treatment whatsoever.
Next
Return to Espresso Machines
